Inventor Forum
Sub-assembly price in parts list
3 REPLIES 3
340 Views, 3 Replies
Hi!
I have an assembly made of 8 different sub-assemblies (some of them repeat). How do I make a parts list showing all sub-assemblies and their prices? I have already made parts lists for individual parts and their prices for each sub-assembly.
Thank you
3 REPLIES 3
johnsonshiue
Hi! If each subassembly is unique, you can simply use BOM Structured View to show each subassemblies. If some of them are instances of a subassembly, they will roll up as one row.
Inventor 2021 and earlier is not yet able to create instance properties. We are working on a project enabling such behavior. You can sign up Inventor Feedback Community (https://autode.sk/InventorBeta) to try it on an internal testable build.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
Hi Johnson Shiue,
Thank you for your answer. I have another question.
When I open the BOM structured view of the said assembly I see all the sub-assemblies but the estimated cost column is blank for all of them. When I expand a sub-assembly I see the estimated costs  for all the parts and their QTYs but the estimated cost for the parent sub-assembly is still blank.
Any ideas?
Thank you
mcgyvr
The estimated cost field is a manually filled out field.
You would need to manually enter the value for the subassembly just like you did the parts or use some ilogic,etc... to loop through an assembly and set that value.
https://forums.autodesk.com/t5/inventor-customization/calculate-total-assembly-cost/td-p/6412356
Technology Administrators
