Calculate total assembly cost
Message 1 of 15
I've written a piece of iLogic code which calculates the material and labour costs of all my manufactured parts and writes the value to the 'Estimated Cost' iproperty. My code reads from an excel pricing sheet so that all the costs are kept up to date, I've even got it to calculate the labour costs of any assembly files  ...so far so good
However at the final hurdle, I've ran into some difficulty when trying to generate a total cost of all parts and assemblies through exporting my top level BOM to an XLS document.
I think I'd like to export a first-level only BOM, but for this to work I need each assembly to total up the costs of each of its sub-parts.
Can anyone suggest a piece of code I could use to do this calculation?
Something like:
If openDoc.DocumentType = 12291 Then
iProperties.Value("Project", "Estimated Cost") = Total cost of assembly sub-parts + assembly labour
Replies (14)
Message 2 of 15
Jef_E
Hi!
I whipped somthing up real quick.. This code count all occurrences in the assembly their cost and add them up. It does not check if the occurrence is suppressed or BOM-Structure is reference/phantom. It just counts every thing.
If you want to make exceptions I can help you with that also. Just ask 🙂
Sub Main TraverseAssemblySample()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
     oAsmDoc = ThisApplication.ActiveDocument
	 Dim oCost As Decimal
	 oCost = 0
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, oCost)
	MsgBox(oCost)
End Sub
Private Sub TraverseAssembly(ByVal Occurrences As ComponentOccurrences, _
							 ByVal Level As Integer, _
							 ByRef oCost As Double)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    For Each oOcc As ComponentOccurrence In Occurrences
		' Get the document file for this occurrence
		Dim oDoc As Document
		oDoc = oOcc.Definition.Document
		' Get the iPropertySet that constains the estimated cost property
		Dim oPropSet As PropertySet
		oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
		' Get the cost of this occurrence
		oCost += oPropSet.Item("Cost").Value
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, oCount)
    Next
End Sub
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 3 of 15
Found a piece of code on another post that works a treat for summing the total of all the parts/assemblies
http://forums.autodesk.com/t5/inventor-customization/ilogic-how-to-sum-a-property-of-all-sub-assembl...
Now though I need to establish the correct event trigger and none seem to fit the bill!
I basically need this rule to run in my assembly when the value of one of the sub-parts change. Is this impossible?
Message 4 of 15
@Jef_E
Thanks Jef, your code works great. One issue I have with the other one is that it doesn't include the cost of parts that are in a phantom assembly.
Ideally, I'd like the phantom assembly to remain at a value of 0 for it's cost (in another part of my rule it set's the value of any phantom parts to 0) and have my main assembly include the parts within my phantom assembly in it's calculation.
Any idea how to alter yours or the other code to achieve this?
This is the other code as I am using it:
'clear the custom property in the assembly
iProperties.Value("Project", "Estimated Cost") = 0
'set a reference to the assembly component definintion.
'This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'custom property in the assembly
xNumber = iProperties.Value("Project", "Estimated Cost")
'custom property in the parts
yNumber = iProperties.Value(oOccurrence.Name, "Project", "Estimated Cost")
sumNumber = xNumber + yNumber
'set custom property values
iProperties.Value("Project", "Estimated Cost") = sumNumber
Else
Next
Message 5 of 15
Jef_E
I modified the code marked with red. Now the phantom AND reference parts are skipped by the code.
	 oCost = 0
	MsgBox(oCost)
End Sub
		' Skip Phantom and reference parts.
		If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure _
		Or oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
			Continue For
    Next
End Sub
Inventor 2014 SP2
Message 6 of 15
Any idea how I would get it to include the parts that are inside those phantom assemblies?
These phantom assembly files are just being used to group together some common parts in a certain arrangement, I still want the parts within them to be included in the sum.
Message 7 of 15
Jef_E
Dim oCost As Decimal oCost = 0 ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, oCost) MsgBox(oCost) End Sub Private Sub TraverseAssembly(ByVal Occurrences As ComponentOccurrences, _ ByVal Level As Integer, _ ByRef oCost As Double) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. For Each oOcc As ComponentOccurrence In Occurrences ' Skip Phantom and reference parts. If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure _ Or oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
' Do Nothing Else ' The occurrence is valid count the cost. ' Get the document file for this occurrence Dim oDoc As Document oDoc = oOcc.Definition.Document ' Get the iPropertySet that constains the estimated cost property Dim oPropSet As PropertySet oPropSet = oDoc.PropertySets.Item("Design Tracking Properties") ' Get the cost of this occurrence oCost += oPropSet.Item("Cost").Value End If ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, oCount) End If Next End Sub
It's not rocket science 🙂 here is the edit. Didn't test it.. don't have Inventor here.
Inventor 2014 SP2
Message 8 of 15
    Next
End Sub
Great stuff, but shouldn't oCount be oCost?
Message 9 of 15
Thank you both for your replies, I'm relatively new to iLogic so when it comes to writing my own code, sometimes I'm not sure where to start or what terminology to use to access the information I need.
However when I read through your code I understand it quite well. I couldn't find a solution to my problem of getting the rule to run in an assembly anytime the BOM was changed, so I used the 'After Save Document' event trigger.... I think you know where this is going 🙂
Because the rule uses the active document, when I save my top level-assembly and the rule runs in all my sub-assemblies, it's not accessing the correct  component occurrences of those assemblies and giving me a wrong value. Is there a simple fix to this?
Message 10 of 15
I should also add, although the code skips any phantom assemblies but includes their parts. It also calculates the total of all parts through every level.
For example, the total cost of my final assembly comes in at £140.62, based on the BOM below.
Whereas I only want it to calculate the following, giving a value of £88.47:
The cost of A01908 includes the cost of it's two sub parts + labour costs
Message 11 of 15
Jef_E
Why would you want the code to run evry time you save? Just let it run when you want to know to cost? Add a button in the iLogic browser "Show Cost" and voila?
Inventor 2014 SP2
Message 12 of 15
Jef_E
Sorry in my opinion there is no logic to this.. Your assembly cost = 80.89 but the content is around 50? I gave the solution to the problem stated. Please work out your own tweaks that come out afterwards.
Inventor 2014 SP2
Message 13 of 15
This snippet of code is part of a universal rule that exists in all of our part/assembly file templates. So I need the rule in each part to run when there are changes made to it. This is easy in a part file as there are event triggers specific to changes in geometry/parameters (i.e. the length of the part). But this is a bit trickier getting the assembly to update it's total cost when you add/remove a part, the rule needs to run again after the assembly has been changed to calculate the new cost. I can achieve this by setting the 'Before save' event trigger, so that the user just has to save the top level assembly and all sub parts/assemblies with changes made to them will run the rule and update their cost.
To overcome the issue I was having before I changed ThisApplication.ActiveDocument to ThisDoc.Document, and it works perfectly now 🙂
Message 14 of 15
The cost of the sub-parts combined are approx 50 yes, but what you are not seeing is another part of my rule that calculates the labour cost of that assembly (approx 30) and adds this to sub-parts cost, giving me my total cost of 80.89 for that assembly.
Message 15 of 15
shadowcaster111
I could use a copy of that finished code
that adds in the labor
sounds like just the thing to solve a problem I have
