Inventor Forum
Change Content Center Library Family Internal Name?
2 REPLIES 2
Calvin.hendriks
812 Views, 2 Replies
How do I change the internal name of a family in the content center library? I have two content center libraries. They were both derived from the built in ANSI library. One has imperial dimensions, and one has metric dimensions. If I have them both active in a single project I can only see one of the two when placing from content center. If I go into the Content Center Editor, and from the dropdown select one library I can see the parts from that library. If I switch the dropdown to the other library I can see those respective parts as well, but in the merged view it only shows one of them, not both.
I made a third content center library and tried to copy one of the members there from each of the two existing libraries to see how it would behave. For example, I copied Rectangular HSS from both the metric and imperial libraries to the new library, and upon copying the 2nd one I receive an error (see attached screenshot) that I believe is the root of the issue. How do I change the internal name of the family within the content center library so that they are "unique" within the library?
Labels (4)
2 REPLIES 2
A.Acheson
in reply to: Calvin.hendriks
@Calvin.hendriks
Right click on the family icon when in the editor mode and select family name etc.
https://m.youtube.com/watch?v=_J9gM1Q1_Ss
Hope that is what you were looking for.
Regards
Alan
A.Acheson
in reply to: A.Acheson
@Calvin.hendriks
Dug into this further. Looks like your using the Copy to Read/write folder. You can have only one copy of a family in this folder using that method. It brought up the same error message when I tried to copy the family in twice but there is an internal stop to prevent this.  There is  a direct link back to the read only folder you can suppress the link but not break the link . .[One  Dog] Trained!!
If you use the Save Copy As with or without a link to the parent family you can  make as many copies as you like without the error message. ..[A litter of puppies] Need help!!
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
Every day a school day.
Regards
Alan
Technology Administrators
