- Mute
- Permalink
- Report
My colleague mentioned he saw some strange behavior when dimensioning 2D drawings where it seemed he was getting wrong/crooked dimensions on his ortho views.
After looking into it we found the following workflow that causes this issue:
- Have a part with differences in depth and create a new drawing.
- Make sure to start out with an isometric view or custom orientation that is not orthogonal
- Edit the view to make it orthogonal
- Dimension from a line/point to another line/point that has a depth difference.
This should give an isometric dimension in an orthogonal view, which is unexpected and, depending on if it's a small difference, can go unnoticed.
When placing a a view and starting out orthogonal this behavior isn't present.
This is on IV2021.3.1
@johnsonshiue i've attached my testpart, but it's easy enough to recreate with other geometry as well.
Can you confirm this behavior and see if it's present in IV2022 as well?
We would love to see this fixed.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
