Inventor Forum
Inventor remembering folder location
1 REPLY 1
bradeneuropeArthur
69 Views, 1 Reply
Why is Inventor not remembering (the last) folder location when opening a filedialog?
Is there an option to set this?
@johnsonshiue Do you or your team have a clue?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
1 REPLY 1
Are you opening with or without code? A simple solution is when the system fatal errors, it reverts back to the previous dialog and I've had issues when a project file is out of sync with the vault in that envirorment.
Technology Administrators
