Inventor Forum
Inventor remembering folder location
2 REPLIES 2
bradeneuropeArthur
127 Views, 2 Replies
Why is Inventor not remembering (the last) folder location when opening a filedialog?
Is there an option to set this?
@johnsonshiue Do you or your team have a clue?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
2 REPLIES 2
Are you opening with or without code? A simple solution is when the system fatal errors, it reverts back to the previous dialog and I've had issues when a project file is out of sync with the vault in that envirorment.
It is the default open dialog without code.
Arthur Knoors
Technology Administrators
