Diamond Knurling
Diamond Knurling
Scary99
Message 1 of 8
Diamond Knurling
Scary99
Is there a command to apply knurling to a cylindrical surface ?
Replies (7)
Message 2 of 8
JDMather
Do you want cosmetic knurl texture (easy) or do you want physical knurl (advanced user)?
Can you attach your *.ipt file here?
Has your instructor covered Splitting Faces?
Message 3 of 8
Scary99
She has not covered splitting faces.  I am attaching file you requested.  The part is a knob and the surface to be textured should be obvious.  Thanks for your help
Message 4 of 8
JDMather
Change the shaded mode to Realistic.
Right click on the cylindrical face and select Properties.
Select the Kurl appearance.
Message 5 of 8
fernandohshilario
Hello @JDMather.
How can I make the knurled pattern appear in my drawing?
Thank you!
Message 6 of 8
kacper.suchomski
Why doesn't the pattern appear in the drawing?
How did you model the geometry?
Attach your file.
Kacper Suchomski
Message 7 of 8
fernandohshilario
See attached.
Message 8 of 8
kacper.suchomski
All the geometry you created is visible in the drawing:
Kacper Suchomski
