iLogic not working as expected
jeremy_wasserstrass
jeremy_wasserstrass
I have been playing with iLogic a bit and I have it finding the extents of my part, however, I am getting an erroneous height coming up for ExtHeight. Would anyone have an idea as to where the .303 dimension is being pulled from? Inventor 2015
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
Curtis_Waguespack
Hi jeremy.wasserstrass,
I didn't look at your part, but do you have visible work features? If so that is likely the issue.
The other thing that is common would be a units conversion issue
edit: a quick search turned up these:
http://forums.autodesk.com/t5/inventor-customization/ilogic-to-get-part-extents/td-p/6051106
https://forums.autodesk.com/t5/inventor-customization/anyway-for-ilogic-extents-to-ignore-workplanes...
I hope this helps.
Curtis
jeremy_wasserstrass
Thanks. The visible work feature would be it, I had the Z-axis visible for easy assembly. I turned that visibility off and I get the correct material Height.
