Unable to open files
Message 1 of 30
I am doing a project using Autodesk Inventor. I sent the files to an Autodesk tutor to comment on but when he returned them I was unable to open the files. Could anyone help me with this?
Replies (29)
Message 2 of 30
mdavis22569
you'll need to provide a bit more info ...what version of Inventor are you on ..
or share the file
HOWEVER ..I'm betting he has a newer version if you're not on 2017.
Mike Davis
Message 3 of 30
JDMather
Students can download the latest version of Inventor from the Autodesk Student Community for free.
Message 4 of 30
My version is 2016 - see attached
Message 5 of 30
Mark.Lancaster
@Anonymous
Did you mean to attach a file?  Nothing is attached
Mark Lancaster
Message 6 of 30
OK. I have found out we both have the same version (2016) Please let me know as soon as possible if you have any ideas. This is urgently needed..
Message 7 of 30
Sorry - here are some samples...
Message 8 of 30
Did that work?
Message 9 of 30
Here is the error message attached.
Message 10 of 30
JimBackull
Hi!
Have you tried to open the files through Inventor´s menu instead of double clicking the file in Windows?
Sometimes I have had troubles when trying to open a file directly from its location, but then it has worked if I go to File -> Open tab -> "Open an Inventor file or other types of CAD files".
I hope this helps you, at least I was able to open your files (though I´m running Inventor 2017).
- Jim
Jim B
Message 11 of 30
BeKirra
I can open your 3 files using v2016.
Unfortunately you haven't attached base components for each of your file.
The following files are missing in your attachment:
Gear 2 (2).ipt
Hour_Tube-01 (2).ipt
Gear 5 (2).ipt
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 12 of 30
Thanks Jim
I believe it may be a Windows 10 problem.what version do you have?
Regards
Karen
Message 13 of 30
JimBackull
Right now I´m working on a Windows 7 PC, but actually I believe I used a machine with Windows 10 & Inventor 2016 when I noticed the issue..
So maybe it´s indeed something related to that!
- Jim
Jim B
Message 14 of 30
blair
All the files are still in version 2016 (build 200138000, 138), so you should be able to open it with your version of IV2016. They all show that they need migrating to IV2017 (I'm on IV2017).
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 15 of 30
I wonder whether there is any way to Private Message you? Damian has significant problems with a complex drawing he has to finish and it is too slow over the forum in terms of communication and misunderstanding especially when his mum tries to post the question.Maybe even a phone call? What is your location and time?
Message 16 of 30
mdavis22569
Who's Tutoring him?
That's where I'd start.  They aren't on the same page.  WIndows 7 to Windows 10 should be an issue. We have a few seats of 7 left at work..
I would recommend getting the newest version (for free like JDMathers said) or at least the same as whom ever is Tutoring/teaching him.
Mike
Mike Davis
Message 17 of 30
JDMather
1. Download and install the Service Packs for 2016.
2. As @JimBackull stated, do not attempt to open file by double clicking the filename - use File Open from within Inventor.
Message 18 of 30
I have a windows 10, as does my tutor...
Message 19 of 30
JDMather
See Post #17.
Message 20 of 30
mdavis22569
Are you both on the same version of Inventor too ..
and install the Updates and patches like JDMather mentioned ...
link to the updates
Mike
Mike Davis
