Anyway for iLogic extents to ignore workplanes?
Message 1 of 11
We have a iLogic Rule that measures extents (length, width + thickness) and for some reason it measures work planes instead of just the model. We have been resizing them until they are no longer sticking out but we don't always rememeber.
Any way to stop this from calculating?
Replies (10)
Message 2 of 11
jdkriek
Please post the rule (code).
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 11
Imports System.Collections.Generic
  ' Make List(of T) type available
InventorVb.DocumentUpdate()
Dim sizes As New List(Of Double)
sizes.Add(Measure.ExtentsLength)
sizes.Add(Measure.ExtentsWidth)
sizes.Add(Measure.ExtentsHeight)
sizes.Sort()
Parameter("LENGTH") = sizes(2)
Parameter("WIDTH") = sizes(1)
Parameter("THICKNESS") = sizes(0)
iLogicVb.UpdateWhenDone = True
Message 4 of 11
jdkriek
Pretty simple 😉
'Turn off work features so they dont calculate
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = False
'Make List(of T) type available
sizes.Sort()
'Turn back on work features - optional
ThisDoc.Document.ObjectVisibility.AllWorkFeatures = True
Jonathan D. Kriek
Message 5 of 11
Gettting this
Public member 'ObjectVisibility' on type 'PartDocument' not found.
Message 6 of 11
jdkriek
Interesting, working fine in Inventor 2011-2013 - unfortunately I don't have 2010 to test with.
So for now just got to View > Object Visibility > Uncheck All Work Features
Jonathan D. Kriek
Message 7 of 11
it's always done this weither they were on or off
Message 8 of 11
jdkriek
As soon as you turn off the workplane it doesn't calculate it, that's how extents works - it has to be enabled.
Here, try this workaround
Dim oApp As Application
oApp = ThisApplication
Dim oPart As PartDocument
oPart = oApp.ActiveDocument
oPart.ObjectVisibility.AllWorkFeatures = False
sizes.Sort()
oPart.ObjectVisibility.AllWorkFeatures = True
Jonathan D. Kriek
Message 9 of 11
Negative jd
Still says Public member 'ObjectVisibility' on type 'PartDocument' not found.
Message 10 of 11
I tried my original rule and it did work when i manualy turned off all work features.
Thanks for clarifing that
Message 11 of 11
jdkriek
Ok, so it must be that 2010 doesnt support that through iLogic. I would find another method in VBA, because it's too easy for someone to turn it back on and mess up your extents. Whereas a script would always make sure it was turned off first before calculating. I'll keep looking for you.
Jonathan D. Kriek
