Inventor Forum
Excel macros and inventor
9 REPLIES 9
Message 1 of 10
1711 Views, 9 Replies
Has anyone used or setup a macro in excel to work on the inventor? For an example, where you can go into a sheet in excel and enter some dimension and hit a button and it draws it up in inventor for you? I have worked with something like this before using Solid Edge program. Not sure if posted this in the right forum. I was just wondering about this and figured i would ask about it.
9 REPLIES 9
Message 3 of 10
in reply to: S_May
Thank you for the links. Can you use the ipart to do assemblies also or is it just parts?
Message 4 of 10
S_May
Hi @Anonymous,
Here are patterns for iparts.
Message 5 of 10
in reply to: S_May
Thank you for the link again. My question was can you do a assemble as an ipart?
Message 6 of 10
S_May
iPart in assembly
ipart is only for models, for modules there is ilogic
or assemblies over master sketch as ipart
Message 7 of 10
in reply to: S_May
Ok. I will have to play around with this and try to learn how to do it. I just was wondering if you could use excel with inventor.
Message 8 of 10
MechMachineMan
As far as vb/vba/macros: Yes. Both API's are accessible. It really doesn't matter where you run them from as long as they can connect to inventor.
As far as non-programming related: Yes. You can embed excel spreadsheets, use iLogic, and they are an embedded part of positional representations and linking parameters.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 9 of 10
in reply to: MechMachineMan
Where can i find information on this? I would like to read up on it and try my hand on doing some of this. I'm trying to learn all the stuff I can with inventor. Thank you.
Message 10 of 10
MechMachineMan
Inventor customization forum has a lot of posts (see especially the stickies "My First Plug-in") My forum signature has some links in. The autodesk reference material for iLogic has some.
The Programming Help available offline through inventor (question mark dropdown in top right corner of application window), or online through the autodesk help > developer documentation also has a lot of info.
Justin K
