Inventor Forum
Drawing : Section view : Arrows
13 REPLIES 13
Message 1 of 14
Ktelang
7030 Views, 13 Replies
I need to change the arrow style from that available in inventor to custom defined one.
Precisely I want arrow to look as in image attached (circle type of arrow).
I tried editing the sketch of the section line but its not helping.
I tried defining sketch symbol but the extension line still remains in the view.
Please can anybody help ?
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
13 REPLIES 13
Message 2 of 14
johnsonshiue
in reply to: Ktelang
I am not quite following what you meant by "extension lines still show in the view." Could you post an image of your custom-made symbol or attached the IDW file with the sketch symbol defined?
Thanks!
Software Test Engineer
Message 3 of 14
Ktelang
in reply to: johnsonshiue
Thanks for your time.
The extension line is the line between the
section line and the arrow head. Please see the
attached picture.
I have changed the arrow style to none. But thats not enough
I do not want the remaining line  (extension line too)
Thanks again
Message 4 of 14
I have the same issue with making the section line symbol look like a Civil Engineering type style.
Did you have any luck making a work around?
Message 5 of 14
Lewis.Young
Hi there,
I have a solution, but this may not work for your exact drawing.
If you go into the annotation style and change the format so its the first one, it will change the style of the extension line.
Now, if you're lucky, the extension line will now overlap an existing line so it's essentially hidden. Then all you have to do is double click on the text and simply remove what's in the text box.
This of course isn't a solid answer to your question, but there doesn't seem to be a real way of removing the line completely.
Anyway, I hope this helps 🙂
Lewis
Message 6 of 14
"Extension line length" set to 0 doesn't remove it?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 14
I'm pretty certain the extension value can't be set to "0", not sure why though, it would save a lot of time!
Message 8 of 14
evettem
IS THERE A SOLUTION FOR THIS YET?
Message 9 of 14
MechMachineMan
in reply to: evettem
YES.
Create sketched symbols to place over the endpoints of the section lines. Hide the native section line arrows as shown above in this thread.
If that isn't good enough for you, pay someone to write you code that automatically inserts them, or go find/make the idea on the idea forums.
Justin K
Message 10 of 14
Hi
I think I have a fix to your problem. If you don't want to see the section line (or detail circle/boundary) in a base view - double click on the Section (or Detail) view. Select the "Display Options Tab" . There is a check box "Definition in Base View" if this is unchecked the section line won't be displayed.
Other option is to put the Section line on a layer that doesn't print.
Message 11 of 14
Cris-Ideas
Quite old,
but I am just struggling with the same problem.
Solution I found is to set:
Extension Line length = 0.01mm
arrow type = None
X scale = 0.01mm
This basically removes extension line as far as all practical applications are concerned.
The end of the line is no more available for dragging from the sheet level and for any edit you need to enter the sketch, or temporarily style of the section line
Cris
Cris.
Cris,
https://simply.engineering
Message 12 of 14
Cris-Ideas
in reply to: Cris-Ideas
@johnsonshiue
Hi Johnson,
since you are in this tread, do you know the way of controlling the length of the last visible segment of the section line? The one that does not get turned off when "show entire section line" option is off.
I tried every available parameter I could think off and nothing worked o far.
Cris.
Cris,
Message 13 of 14
rhasell
My solution to the problem:
Set the section line layer to non printable, I also changed the colour so that it is more visible, and indicates something that does not print.
I am now so used to it and managing section lines is a thing of the past, I don't have to worry about the exact length or placement, as it is never seen, and I can make them as long or short as I wish. My DWG export automatically hides the section layer.
Reg
2024.2
Please Accept as a solution / Kudos
Message 14 of 14
Cris-Ideas
in reply to: rhasell
Different angle of approach.
Will explore this direction.
Cris.
Cris,
Technology Administrators
