Inventor Forum
From DWG to SAT ... with a strange result
10 REPLIES 10
Message 1 of 11
mirko.saiani
277 Views, 10 Replies
Hello!
I have a DWG with solid
I need to convert in .sat to use in Inventor
This is the result of convertion:
Now I want to a family in Revit ... but doesn't work!
What is the problem??
thanks!!!!
mir
10 REPLIES 10
Message 2 of 11
Cris-Ideas
in reply to: mirko.saiani
How are these solids created?
Are there any splines involved?
What happens when you try different format (igs, step)?
Can you share the model?
Cris.
Cris,
https://simply.engineering
Message 3 of 11
mirko.saiani
autocad plant 3d or autocad
I tried to convert with only solids
igs/iges no result
Can you share the model? yes privated?
Message 4 of 11
CCarreiras
Before you spend much time on this:
This is a complex geometry to convert to a Revit file.
Revit doesn't have the capability to accept such a detailed geometry... and even if you can convert this file to a Revit format, the file will be too big to use in a Revit project. The time you import the family file on a Revit project, Revit will become too heavy to handle and it will start to hang. The final Family file must have less than 10Mb (more or less).
I suggest you simplify the geometry first, Inventor has SIMPLIFY tool to do that, or simply create a substitute with the significant sizes (kind of a bounding box to represent all the system).
But... if you want to try it, you should consider this:
  1. Have you tried to import the 3D dwg in inventor directly? (import, not open).
  2. Have you tried to convert the 3D dwg to STEP format, instead of SAT?
CCarreiras
Message 5 of 11
Cris-Ideas
So I did try.
Export from your file fails, there is something wrong with it.
I have copied everything (Ctrl + C) (Ctrl + V) in to fresh AutoCAD file and export from there worked fine.
Try on your end.
Cris.
Cris,
Message 6 of 11
mirko.saiani
in reply to: CCarreiras
Hi CCa!
ok but the problem is from dwg to sat.
after I can simplify the file like you say with inventor!!
with autocad I can't to export in step ...
Message 7 of 11
Cris-Ideas
I have exported to sat. from AutoCAD and imported to AI.
Cris.
Cris,
Message 8 of 11
mirko.saiani
in reply to: Cris-Ideas
sureeeeeee??
I try!
Message 9 of 11
CCarreiras
You can export to step with AUTOCAD MECHANICAL.
CCarreiras
Message 10 of 11
JDMather
Why the conversion to ACIS (*.sat)?
Can you Attach your *.dwg file here?
Message 11 of 11
mirko.saiani
NICE!
it's worked  perfectly!
thanks! thanks!
Technology Administrators
