Hello!
I have a DWG with solid
I need to convert in .sat to use in Inventor
This is the result of convertion:
Now I want to a family in Revit ... but doesn't work!
What is the problem??
thanks!!!!
mir
Solved by Cris-Ideas. Go to Solution.
How are these solids created?
Are there any splines involved?
What happens when you try different format (igs, step)?
Can you share the model?
Cris.
autocad plant 3d or autocad
I tried to convert with only solids
igs/iges no result
Can you share the model? yes privated?
Before you spend much time on this:
This is a complex geometry to convert to a Revit file.
Revit doesn't have the capability to accept such a detailed geometry... and even if you can convert this file to a Revit format, the file will be too big to use in a Revit project. The time you import the family file on a Revit project, Revit will become too heavy to handle and it will start to hang. The final Family file must have less than 10Mb (more or less).
I suggest you simplify the geometry first, Inventor has SIMPLIFY tool to do that, or simply create a substitute with the significant sizes (kind of a bounding box to represent all the system).
But... if you want to try it, you should consider this:
So I did try.
Export from your file fails, there is something wrong with it.
I have copied everything (Ctrl + C) (Ctrl + V) in to fresh AutoCAD file and export from there worked fine.
Try on your end.
Cris.
Hi CCa!
ok but the problem is from dwg to sat.
after I can simplify the file like you say with inventor!!
with autocad I can't to export in step ...
I have exported to sat. from AutoCAD and imported to AI.
Cris.
Why the conversion to ACIS (*.sat)?
Can you Attach your *.dwg file here?
