When modelling a circular spring (modeling method: https://www.youtube.com/watch?v=ihM4uLzxeI0) I stumble upon a problem. As soon as the twist angle exceeds 9000deg, the sweep fails. Tried everything I could think of but no result. Anyone has a suggestion? thx in advance! FYI I should be able to input a twist angle of 10440deg. I calculated this would keep a space of appr. 0.01mm between the inside of the coils. I use Inventor 2019.4.2
Please attach the part
I think there is a more efficient way of doing this in Inventor 2019.
I would probably use a Sweep with Twist and Animate Parameter.
I've drawn it with sweep and a twist angle. I dont understand what you would do by animating the parameter...
Hi! Animating parameters is a workflow in Inventor Studio, not in Inventor modeling environment.
Many thanks!
