Inventor Forum
circular spring
6 REPLIES 6
332 Views, 6 Replies
circular spring
When modelling a circular spring (modeling method: https://www.youtube.com/watch?v=ihM4uLzxeI0) I stumble upon a problem. As soon as the twist angle exceeds 9000deg, the sweep fails. Tried everything I could think of but no result.  Anyone has a suggestion? thx in advance!  FYI I should be able to input a twist angle of 10440deg.  I calculated this would keep a space of appr. 0.01mm between the inside of the coils. I use Inventor 2019.4.2
6 REPLIES 6
mcgyvr
Please attach the part
in reply to: mcgyvr
To make it complete, I'm not able to attach files to my messages...
in reply to: mcgyvr
The files in attachment
TheCADWhisperer
I think there is a more efficient way of doing this in Inventor 2019.
I would probably use a Sweep with Twist and Animate Parameter.
in reply to: TheCADWhisperer
I've drawn it with sweep and a twist angle. I dont understand what you would do by animating the parameter...
johnsonshiue
Hi! Animating parameters is a workflow in Inventor Studio, not in Inventor modeling environment.
Many thanks!
Software Test Engineer
Technology Administrators
