Inventor Forum
Content Center ANSI filter stopped working
5 REPLIES 5
3D4Play
418 Views, 5 Replies
Tried placing a jamb nut from content center just now. The ANSI filter applied shows no results. Removing the filter shows all available results including ANSI content.  (?) Yes, the filters are set to include all ANSI content. Yes, the content center is set up correctly, and the file locations are correct in the project workspace. Screenshot 1 is looking for the content with ANSi filter applied. Screenshot 2 is showing the filter applied, screenshot 3 is showing the results when the filter is removed. Why might this be happening?
kelly.young has embedded your images for clarity.
5 REPLIES 5
dsl145
in reply to: 3D4Play
Could you post what the two tabs in the filter looks like? I can't think of what the problem would be outside of something in there.
What about creating a new filter and seeing if that shows up correctly?
olof_andersson
I got the same problem but with Inventor 2020. Did you find a solution?
jan_priban
in reply to: olof_andersson
ANSI filter definition should look like
Is ANSI library defined in active project?
Regards
Jan Priban
Hi all,
 it should be fixed in Released 2020.1.
Roman Vesely
Inventor - Principal QA Engineer
jan_priban
in reply to: Roman_Vesely
two tips:
- Modify project, exclude all libraries except ANSI
https://forums.autodesk.com/t5/inventor-forum/filtering-content-center-by-library/m-p/8861303#M74956...
- Add your ANSI families into Favorites, works with favorites (=place CC parts from Favorites)
Regards
Jan Priban
Technology Administrators
