LIVE CHAT
LIVE CHAT
Message 1 of 12
LIVE CHAT
Autodesk used to provide a live chat option.  Where did it go?  Help please!
Replies (11)
Message 2 of 12
TravisNave
You might add this to the Idea Station. It might be something good for them to offer.  🙂
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 12
Which Idea Station would that be?  There are quite a few.
Ben
Message 4 of 12
ploter not working in 2016 auto cad
Message 5 of 12
Mark.Lancaster
@Anonymous
Welcome to the community..
This is not place to post this type of question or hi-jack someone else's posting on a totally different subject matter..  Please use the Autocad discussion forum for this type of question.   And when you do post, please indicate your AutoCAD version, your plotter, and the OS you have.   However plotters in AutoCAD are controleld by your windows driver so that would be the first place to look since you description is so generic
@Anonymous
Please indicate the subject matter regarding your live chat.  There's a couple of them but they are for a certain subject matter.
Mark Lancaster
Message 6 of 12
kindly share Autocad 2012 LT download link
Message 7 of 12
Mark.Lancaster
@Anonymous
For future reference I might suggest that you create your own posting instead of hi-jack another that has nothing to do with your needs.
All Autodesk 2012 version is obsoleted and no longer support by Autodesk which means there's no "live" links to Acad LT 2012.   What is the reason why you need a legacy version?  Do you need to reinstall it?  Just because you have a serial # and product key for it doesn't mean its going to activate due to the history of that serial #.
However someone from Autodesk may chime in and give you a short term link to Acad LT 2012.
Mark Lancaster
Message 8 of 12
pendean
Community Legend
Community Legend
You need to do what this Autodesk staff member notes here, no guarantees though https://forums.autodesk.com/t5/autocad-lt-general-discussion/autocad-lt98/m-p/6478903#M142004
Message 9 of 12
rajjn084
Community Visitor
Community Visitor
can i run 3ds max 2017 in 4gb ram
Message 10 of 12
Mark.Lancaster
@rajjn084
May I ask what your request has to do with live chat..  Next time create your own posting and not hi-jack someone's posting that has nothing to do with your needs.  Smiley Wink
4GB of ram is the bare min to run that application.  It will be very slow since Autodesk is really recommending 8GB..  Hopefully your machine is based on a  64BIT OS..  Remember you don't really have 4GB to run the application since a percentage of that ram is being used for the OS.
Mark Lancaster
Message 11 of 12
Hi
If I scribe for the Fomit360 for my desk top, can I able to down load formit 360 on my ipad pro using the same licence.
Angelo
Message 12 of 12
Mark.Lancaster
@Anonymous
This is not a live chat..  Someone was asking about where the live chat functions went to..  Please do not hi-jack other postings that have nothing to do with your issue.  Create your own posting and requirements.  Smiley Wink
Now to your problem..  Yes you should be able to do this because its authorized by your named Autodesk Account.  But you can't be running the same time.  In addition I would assume the software is capably of running on your iPad.
Mark Lancaster
