Problem installing Autocad for Mac
Message 1 of 27
Hi!
I'm trying to instal Autocad for Mac on a Macbook Pro Retina with El Capitan 10.11.4 .
When i'm installing Autocad at the end of the installation, appear this message "The installer encountered an error that caused the installation to fail".
How can i solve it?
Replies (26)
Message 21 of 27
maxim_k
Can you attach install.log from your main account again? After the last installation attempt.
And - now you can delete new account, created today for installation testing.
In this post:
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-2016-mac-fail-to-install/m-p/6067311#M...
Hao advised to use a script for installation which was attached to his post. I think as last attempt you can try it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 27
ok, here the new install.log
Message 23 of 27
maxim_k
Now I see that you have permission problems with SUDO command which is necessary to complete AutoCAD installation. Here are some lines from log file you attached:
Apr 22 20:44:27 MacBook-Pro installd[384]: ./postflight: sudo: unable to stat /etc/sudoers: Permission denied
Apr 22 20:44:27 MacBook-Pro installd[384]: ./postflight: sudo: no valid sudoers sources found, quitting
And now look at this discussion:
https://discussions.apple.com/thread/3680870?start=0&tstart=0
I thin you can find the solution there.
Try at first not to experiment with root user, simply reinstall OS X in place from the Recovery partition. This should repair permission problems.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 27
Thank You....So the procedure that i have to try is :
Correct Answer Solvedby Linc Davis on Jan 24, 2012 4:41 PM
Back up all data, if not already done. Boot from your recovery partition (command-R at startup) and reinstall Lion. If you upgraded from 10.6, you'll need the Apple ID and password you used to buy Lion from the App Store. Don't erase the boot volume; just reinstall in place. You won't need your backup unless something goes wrong.
or first i try with Root User?
Message 25 of 27
maxim_k
I would start with reinstalling OS X from recovery partition
M
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 26 of 27
it works!! thank you, thank you, thank you! after more than 8 hours to download the OS...thanks for your quickly reply.
Last question: can i uninstall autodesk 360 without problems?
Message 27 of 27
maxim_k
You don't need to uninstall it, just remove it from Login items in your account in Users pane of OS X System Preferences. Than log out and log in again or restart your Mac - Autodesk 360 will never start again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
