Problem installing Autocad for Mac
Message 1 of 27
Hi!
I'm trying to instal Autocad for Mac on a Macbook Pro Retina with El Capitan 10.11.4 .
When i'm installing Autocad at the end of the installation, appear this message "The installer encountered an error that caused the installation to fail".
How can i solve it?
Replies (26)
Message 2 of 27
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried downloading from the virtual agent?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 3 of 27
Thanks for the reply.
I tried to install the 2014 version of Autocad that i had installed on my old MacBook White 2009, and that time everything went ok, on my new MacBook and the result is the same as the 2016 version. Now i'm trying to download 2014 version from virtual agent and then i will try to install it.
Message 4 of 27
Nothing...same problem with Autocad 2014 download from virtual agent.
what can i do?
Message 5 of 27
maxim_k
Please look at this topic:
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-2016-mac-fail-to-install/m-p/6055915/h...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 27
hi
can you explain me which procedure i have to follow?
thanks
EDIT
where is folder /tmp?
Message 7 of 27
maxim_k
To jump into TMP folder you can use menu Go in Finder : switch to Finder, select menu Go -> Go to Folder, type /tmp and pick on OK - you are inside TMP folder.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 27
I delete all items in /tmp and re-install Autocad...always same message. 😞
Message 9 of 27
maxim_k
Can you attach INSTALL.LOG file?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 27
Sorry...where i found the install.log file?
Message 11 of 27
maxim_k
You can find install log at the following place:
/var/log/install.log
As with TMP folder you can use Go to folder menu in Finder to reach /var/log folder.
Install.log file could be very large in size, so compress it before attaching.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 27
ok..here the install.log....i suggest you to watch the 20 and 21st april, i tried to install autocad in these days
Message 13 of 27
maxim_k
Please, double check that Autodesk 360 is not running (and installed) on your Mac. From the INSTALL.LOG file I can see that the problem with installation occurs at the moment when Autodesk 360 installation starts.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 27
Ok...now i can't check it, but i tried to install autocad after i uninstalled autodesk 360, and same error....later i will make another check and attempt....in another post i read that a solution is make a time machine backup and then re-install the OS....what do you think?
Message 15 of 27
maxim_k
>>> tried to install auto cad after i uninstalled autodesk 360
If you have Autodesk 360 running on your Mac - you need to REMOVE (uninstall) it before installing AutoCAD, because it prevents you from successful AutoCAD installation. For the instructions look here:
http://forums.autodesk.com/t5/autocad-for-mac-general/active-autodesk-360-instance-detected-error-me...
About Time Machine solution - I wouldn't began to be engaged in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 27
So, i unistalled everything about Autocad and autodesk 360 with the app AppCleaner,deleted also in Login Items, i restart the Mac, try to install but the message appear another time.
now?
Message 17 of 27
maxim_k
Are you installing as Admin?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 27
I'm the only user....i think i'm the admin....before start installation ask me to insert the password, so i think i'm the admin....what can i do to be sure?
Message 19 of 27
maxim_k
You can check your account in Users pane of OS X System Preferences. But I believe, you are Admin.
Have you tried to create (just for test, you can remove this account later) new Admin account, login to it and start AutoCAD installation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 27
even with another administrator user, the same error
