- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Well, it's that time again... and this time it's a required update as of April 1, 2022 for all Autodesk 202x products. If you are still using network licensing for enterprise or token flex, it's time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version, which looks to be the same as the 2022 release. See below:
Autodesk is again providing 11.18.0.0 (x64 only) for 2023 products for those of you who are still on network licensing and have not yet moved to Named User licensing. In addition, the NLM should still be available for Enterprise support level customers for the time being. If you haven't already updated to this version for your 2022 product, it is required that you update this and any 3rd party Flexera versions that you may be running to this release from Revenera or newer, by April 1st 2022 per Autodesk.
NOTE: If you do not update with this release, you may get a 0.0.0 error.
For detailed installation instructions see this link:
Just like the last couple of years and moving forward, the License Manager files are no longer available for direct download from Revenera. Per their existing policy, you must obtain the license manager from your software vendor. You can download the Autodesk Network License Manager files here for only the 64-bit version moving forward:
You can update your license file to 2023 versions from your Autodesk Accounts page once your Subscription has been updated. Note: Just because the Autodesk product has been released, there is no guarantee that your Subscription has been updated yet.
Autodesk Product Keys for all versions can also be found here. With the latest changes to future installs, Product Keys will likely become antiquated. Product keys for 2023 should follow the same formula if required, with this release using the letter O.
You can use the online method to activate your license here:
https://register.autodesk.com and from your Autodesk Accounts page at https://accounts.autodesk.com
Or you can contact your Value-Added Reseller for assistance. You can locate your VAR here:
http://www.autodesk.com/resellers/locate-a-reseller
Note: To update your license file, you will need to provide your serial number and ethernet ID of the new/current license server.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
Good Luck!
Travis Nave
