Fusion Support
Windows 11
64 REPLIES 64
Message 1 of 65
Ait-Tek
18325 Views, 64 Replies
Windows 11
Hi all
I am itching to try Windows 11 but concerned that I could run in to issues with my Fusion. what's the latest on this release with F360 please
64 REPLIES 64
Message 41 of 65
@dhayes386 Did you ever apply for a education license using the same email ID?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 42 of 65
@jan.hartmannFSSDE Is there an error when you are trying to sign in or does it bring you back to the login screen?
Autodesk Fusion
Join Fusion Insider
Message 43 of 65
So I can enter my Email and Password. After that, I'm asked to close another session (I don't have any other session open). When I tick the box to close the other session, fusion freezes.
A colleague of mine also tried to open fusion with my account, but is unable to.
I also tried it on a Windows 10 VM and had the same outcome.
Kind regards
Jan
Message 44 of 65
I may have at one point
Message 45 of 65
@jan.hartmannFSSDE Do you work on multiple machines or logged into Fusion on any other machine in the recent past? Can you you launch Fusion and while it is coming up hit CTRL + SHIFT and this should bring up the Fusion service utility. In there can you please run the gather system info and past the zip files generated here?
Autodesk Fusion
Join Fusion Insider
Message 46 of 65
So I made some progress.
I used an hotspot to login and bypass the Router. Funny thing is, it was working until yesterday fine on our network.
Now I have the Problem that Fusion is telling me that my subscription is not valid:
But online, I have a valid license:
Message 47 of 65
jan.hartmannFSSDE
in reply to: Ait-Tek
It seems like my account was moved to some type of education account?
Message 48 of 65
@jan.hartmannFSSDE Looks like we are still chasing the root cause. If you have not already, can you reset your router to see if that makes a difference? Logout of Fusion 360, close it and then reset the router.
Autodesk Fusion
Join Fusion Insider
Message 49 of 65
We just reset the router. It's the same problem, Fusion hangs at startup.
Kind regards
Jaan
Message 50 of 65
I may have at some point but I do not recall doing so recently.
Message 51 of 65
rcobbjr
I am having the same problem. I am not able to open Fusion 360.  I am using Windows 11. After I try to launch Fusion 360, this is all I am able to do. It was working fine for a month. I tried turning off the internet then launching. It did not resolve the issue. Please link me to the solution
Message 52 of 65
@rcobbjr Can you please try this :
Close Fusion 360,
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Fusion360\ delete the entire Fusion 360 folder
Autodesk Fusion
Join Fusion Insider
Message 53 of 65
I did that. Fusion 360 still will not open
Message 54 of 65
jlukestearns88
I would also like to say that I just recently have had this issue where it loads into the canvas and freezes. I have tried all the suggestions listed above along with hours of reading other forums and "solutions."
Personal account, works just fine on my laptop. After attempting to open it on the desktop and then on the laptop it requires me to log out of the desktop through either suspension or force quit and then runs just fine on the laptop.
Any help would be greatly appreciated as the solutions so far have not produces success
Message 55 of 65
handikram
in reply to: rcobbjr
Exact same as mine. I bought a brand new computer with (sadly) Win 11. I created a hobby account to give this program a shot (I like 3d printing things). When I tried to log onto fusion it brings up the canvas screen but shows expired license at the top and fails to fully load. I have tried using my hotspot instead of my home router with no luck. I have uninstalled and reinstalled. I also logged onto a older desktop with win 10 and it works fine. Its really frustrating me. Anyone have any tips to try?
Message 56 of 65
@handikram Can you please try the below?
1. Close Fusion and make sure that it is not running in task manager
2. Go to Add/remove programs
3. Autodesk Fusion - modify
4. This will launch the Fusion service utility
5. Run the reset Fusion from here
6. now launch Fusion again, it should ask you to login
7. now do you see the right entitlement?
Autodesk Fusion
Join Fusion Insider
Message 57 of 65
I followed the instructions with the same results. Interestingly enough,
when I had my buddy log on this computer it also showed the same error
despite both having valid accounts. I also disconnected from my home router
and used my mobile phone data (different networks) and it responded the
same way.
I also looked and my install file was 4.88 gig's, but the one on the
desktop is in the megabytes, not gigs. Does that sound right? Any other
suggestions? If I need to return the computer I am running out of time. Is
this a windows 11 issue? What other options do I have?
New ASUS laptop, windows 11, firewall disabled, running on a home router
(no proxy server).
[image: image.png]
Message 58 of 65
@handikram Lets take another approach and no you do not need to return your machine. This should just work fine. there is some sync that is likely not happening.
0. Uninstall Fusion
1. Make sure that Fusion installer is not running in task manager
2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
3. On your desktop or where ever the Fusion short cut is please delete that too
4. Do not use the same Fusion installer. Can you please download the installer again? (make sure that 360 is not found in the installer name)
5. Now install again
Autodesk Fusion
Join Fusion Insider
Message 59 of 65
I uninstalled, deleted folder and desktop link, and downloader app. Re-downloaded the installer. Reinstalled. Got the same failure. heavy sigh
Message 60 of 65
@handikram Can you please do the below?
1. Login to https://login.autodesk360.com/login
2. Go to a design in a project and select open in desktop
What happens? Is it now syncing the proper license ?
Autodesk Fusion
Join Fusion Insider
