Fusion Support
Machining time is zero after the update
11 REPLIES 11
Message 1 of 12
istvan.pszota
674 Views, 11 Replies
Hello!
After the latest update, the machining time remains zero at the operations list in Manufacturing:machining time.PNG
They however gets visible after a restart.
Istvan
11 REPLIES 11
Message 2 of 12
Hi @istvan.pszota,
Do they stay correct after the restart? Or does this behavior return?
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Message 3 of 12
in reply to: karina.harper
The problem returns even after restarting. i have the same issue
Message 4 of 12
Hi!
After a restart, the previously zero machining times are calculated well.
But if i create a new operation, it's time zero again.
Istvan
Message 5 of 12
in reply to: istvan.pszota
I have a problem too. Showing zero after update. If u start simulation it's showing it after..
Message 6 of 12
istvan.pszota
For me it doesn't.
Message 7 of 12
jeff.pek
Hi -
A question: do you have a machine associated with your setup?
Are you able to share your model (as an export of the .f3d)?
  Jeff
Message 8 of 12
jeff.pek
in reply to: jeff.pek
FYI, we've created a ticket to track this issue: CAM-12430.
Message 9 of 12
istvan.pszota
No, i do not have any machine associated with the setup.
Message 10 of 12
I have the same problem (even after todays 2.0.5331 update).
Fusion360 seems to act up a little after the update, especially the CAM.
For me, closing the file and reopening it or just restarting Fusion helps, but it's really annoying.
Also activating "Manufacture Workspace - Additive Machines" and setting up a mashine does not help.
-Darius
Message 11 of 12
karina.harper
Hi @Anonymous,
This issue was not resolved in the recent update - it is a high priority though and the devs are working on it! Hopefully it will be resolved soon.
Karina Harper
Message 12 of 12
doug
I'm having the same issue.  If I right and use machining time in the menu the times and distance are all there.
Technology Administrators
