Hello!
After the latest update, the machining time remains zero at the operations list in Manufacturing:
They however gets visible after a restart.
Istvan
Hi @istvan.pszota,
Do they stay correct after the restart? Or does this behavior return?
Hi!
After a restart, the previously zero machining times are calculated well.
But if i create a new operation, it's time zero again.
Istvan
I have a problem too. Showing zero after update. If u start simulation it's showing it after..
Hi -
A question: do you have a machine associated with your setup?
Are you able to share your model (as an export of the .f3d)?
Jeff
I have the same problem (even after todays 2.0.5331 update).
Fusion360 seems to act up a little after the update, especially the CAM.
For me, closing the file and reopening it or just restarting Fusion helps, but it's really annoying.
Also activating "Manufacture Workspace - Additive Machines" and setting up a mashine does not help.
-Darius
Hi @Anonymous,
This issue was not resolved in the recent update - it is a high priority though and the devs are working on it! Hopefully it will be resolved soon.
I'm having the same issue. If I right and use machining time in the menu the times and distance are all there.
