Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Machining time is zero after the update
11 REPLIES 11
Message 1 of 12
istvan.pszota
741 Views, 11 Replies
Hello!
After the latest update, the machining time remains zero at the operations list in Manufacturing:machining time.PNG
They however gets visible after a restart.
Istvan
11 REPLIES 11
Message 2 of 12
Hi @istvan.pszota,
Do they stay correct after the restart? Or does this behavior return?
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Message 3 of 12
in reply to: karina.harper
The problem returns even after restarting. i have the same issue
Message 4 of 12
Hi!
After a restart, the previously zero machining times are calculated well.
But if i create a new operation, it's time zero again.
Istvan
Message 5 of 12
in reply to: istvan.pszota
I have a problem too. Showing zero after update. If u start simulation it's showing it after..
Message 6 of 12
istvan.pszota
For me it doesn't.
Message 7 of 12
jeff.pek
Hi -
A question: do you have a machine associated with your setup?
Are you able to share your model (as an export of the .f3d)?
  Jeff
Message 8 of 12
jeff.pek
in reply to: jeff.pek
FYI, we've created a ticket to track this issue: CAM-12430.
Message 9 of 12
istvan.pszota
No, i do not have any machine associated with the setup.
Message 10 of 12
I have the same problem (even after todays 2.0.5331 update).
Fusion360 seems to act up a little after the update, especially the CAM.
For me, closing the file and reopening it or just restarting Fusion helps, but it's really annoying.
Also activating "Manufacture Workspace - Additive Machines" and setting up a mashine does not help.
-Darius
Message 11 of 12
karina.harper
Hi @Anonymous,
This issue was not resolved in the recent update - it is a high priority though and the devs are working on it! Hopefully it will be resolved soon.
Karina Harper
Message 12 of 12
doug
I'm having the same issue.  If I right and use machining time in the menu the times and distance are all there.
