Crashes on attempt to apply coincident constraint to control point spline (attempt to coincide with endpoint of arc (with dimensioned radius) which is coincident with endpoint of line (with dimensioned length and fixed in space) and tangent to that line).
Short screencast of problem:
Thanks for posting! When you crash is there an error report that appears? Are you sending these in?
Also, can you please attach your diagnostic logs here. Thank you in advance! Also, is this happening in only one design? If so, can you please post a link to it?
I'm attaching a zip file of the diagnostics here. (I have sent a few crash reports on this particular crash.)
This particular crash is being tracked internally (FUS-44310) and the developers are looking into it.
For now, I would avoid applying that constraint if it continues to crash, and try to redraw the line so that it starts coincident on that particular point (automatically applying the coincident constraint).
I also encountered crashing when following that sequence (but I can't reproduce the problem reliably). But thanks!
