Fusion Support
Unable to use spline on different sketches
2 REPLIES 2
cyangaze
238 Views, 2 Replies
Beginner here, first time post.  I'm trying to connect the different sketches with the spline tool (tried fit point and control point) but it only works on the top sketch (the circle).  Even if I select different sketches, it still only works on the top circle (1.25 diameter).  Why can't I join these sketches with spline?
Tags (1)
2 REPLIES 2
jeff_strater
in reply to: cyangaze
you need to turn on "3D sketch" to reference points from other sketches or model geometry in the Spline command.
Jeff Strater
Engineering Director
cyangaze
in reply to: jeff_strater
Thanks Jeff!  That totally worked!
