I am working with scripts and noticed that the ADD-INS menu has been relocated to the Manufacturing Workspace as part of the recently updated UI. Error messages on running scripts seem to indicate that this Menu should be in the Design Workspace. I have used the "Shift+S" keyboard shortcut as a workaround from the Design workspace - This works without issues. I Searched the forum and found nothing reported about this particular issue, so would appreciate it if someone could look at it and advise. I was inserting a Spur Gear using the Python script, should you wish to repeat the issue. If you need any further info. please advise...
Solved by karina.harper. Go to Solution.
Hi @Anonymous,
In the new UI preview, the add-ins section is under the "tools" tab.
Thanks Karina - fast response to what now looks like a dumb question....
@Anonymous
Haha, no question is dumb! It's a new layout - sometimes it takes a minute to adapt. If you had the question, others will too
