This problem started after I used the "Microsoft print to PDF"-option in Adobe Acrobat Reader. I don't know if it's related but it seems suspicious.
Now when I try to send a document to my printer, selecting it from the drop-down in the print window, it asks me to select a folder to save the file to instead. I've tried rebooting the computer to no avail.
Solved by ryan.bales. Go to Solution.
This is due to an issue in the latest update. It should still print to your printer if you do in fact select a folder for it to "save" to. Note: it will do both - save a PDF and print to the printer.
I have same issue, but did not start until signing up / setting up team hub
Are you able to print if you select a folder?
