Fusion Support
Report issues, bugs, and or unexpected behaviors youā€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forĀ
Did you mean:Ā
Printer stuck on "Microsoft Print to PDF"
3 REPLIES 3
Stevemedloyden
1248 Views, 3 Replies
This problem started after I used the "Microsoft print to PDF"-option  in Adobe Acrobat Reader. I don't know if it's related but it seems suspicious.
Now when I try to send a document to my printer, selecting it from the drop-down in the print window, it asks me to select a folder to save the file to instead. I've tried rebooting the computer to no avail.
Tags (2)
3 REPLIES 3
ryan.bales
in reply to: Stevemedloyden
This is due to an issue in the latest update. It should still print to your printer if you do in fact select a folder for it to "save" to. Note: it will do both - save a PDF and print to the printer.
Ryan Bales
Fusion 360 Product Support
in reply to: ryan.bales
I have same issue, but did not start until signing up / setting up team hub
ryan.bales
Are you able to print if you select a folder?
Ryan Bales
Technology Administrators
