Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Printer stuck on "Microsoft Print to PDF"
3 REPLIES 3
Stevemedloyden
1237 Views, 3 Replies
This problem started after I used the "Microsoft print to PDF"-option  in Adobe Acrobat Reader. I don't know if it's related but it seems suspicious.
Now when I try to send a document to my printer, selecting it from the drop-down in the print window, it asks me to select a folder to save the file to instead. I've tried rebooting the computer to no avail.
Tags (2)
3 REPLIES 3
ryan.bales
in reply to: Stevemedloyden
This is due to an issue in the latest update. It should still print to your printer if you do in fact select a folder for it to "save" to. Note: it will do both - save a PDF and print to the printer.
Ryan Bales
Fusion 360 Product Support
in reply to: ryan.bales
I have same issue, but did not start until signing up / setting up team hub
ryan.bales
Are you able to print if you select a folder?
Ryan Bales
Technology Administrators
