I cant click on anything or move around any viewport on fusion. I have uninstalled and reinstalled 10 times already and I don't know what to do.
Change your Fusion 360 Graphics Driver and see if it helps. This is found in your Preferences. If this does not work, a little more information is needed, maybe a few screen captures of what you see.
John Hackney, Retired
@charitiwashington Certainly more information would help as @jhackney1972 called out. Are you able to launch Fusion and once it is launched you cannot do anything with it? Can you check to see if you have updated graphics drivers? If you have multiple monitors, can you try to disconnect them and see if there is a difference?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I tried what you suggested but it did not help, I recorded my screen to kind and show the issue. Basically the recording shows me trying to click( everywhere I moved my mouse I was clicking) on the different elements, but I wasn't really able to maneuver around any of the viewports and the only way that I can see the sketch that I made was to split into multiples views. Even then I can not extrude or use any of the other tools. Do you have any idea what could have possibly happen especially since it was working fine a few weeks ago.
@charitiwashington Do you have multiple monitors connected and disconnecting all but the main monitor does not solve the problem, right?
Autodesk Fusion
Join Fusion Insider
@charitiwashington One another thing I want you to try is:
1. Go to Help - Support and diagnostics - Fusion service utility
2. Run the repair Fusion from here
See if this helps!
Autodesk Fusion
Join Fusion Insider
@charitiwashington Couple of things:
1. Are you able to go into Preferences and change graphics setting like @jhackney1972 called out in post #2?
2. Can you let us know what graphics card is on your machine and can you please check if you have the updated drivers for it?
Autodesk Fusion
Join Fusion Insider
1. You have checked that your graphics is up to date right?
2. Also any pending OS updated?
3. Changing the graphics setting in preference I assume did not do anything to help?
Autodesk Fusion
Join Fusion Insider
@charitiwashington OK. This is getting really strange. Let's try a few more things (These are typically graphics but if you are up to date on the drivers then we can look at other things that could be a problem).
1. I see that you do not have the browser on - can you in to View - reset default layout - see if this brings back the access?
Autodesk Fusion
Join Fusion Insider
@charitiwashington I am able to see your first video. The second one seems to be processing so I will wait. Which timezone are you in? I can see if it would be possible to have some one from my team to connect with you for a shared call to see what could be happening.
Autodesk Fusion
Join Fusion Insider
@charitiwashington Seems like you reposted the same first video
Autodesk Fusion
Join Fusion Insider
