Fusion Support
"Pick Circle/Arc Tangent" command no longer works since the new update
2 REPLIES 2
Christoph_360
70 Views, 2 Replies
Hello
Christoph
2 REPLIES 2
You have your sequence off.  You right click and select the Pick Circle/Arc Tangent command BEFORE you select the arc.  See the Animated GIF
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Hello
Absolutely correct, thank you very much for the answer, it works perfectly now.
Christoph
