Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 not working
26 REPLIES 26
Message 1 of 27
charitiwashington
1205 Views, 26 Replies
charitiwashington
I cant click on anything or move around any viewport on fusion. I have uninstalled and reinstalled 10 times already and I don't know what to do.
26 REPLIES 26
Message 2 of 27
jhackney1972
Change your Fusion 360 Graphics Driver  and see if it helps.  This is found in your Preferences.  If this does not work, a little more information is needed, maybe a few screen captures of what you see.
John Hackney, Retired
Message 3 of 27
RajkumarIlanchelian
@charitiwashington Certainly more information would help as @jhackney1972 called out. Are you able to launch Fusion and once it is launched you cannot do anything with it? Can you check to see if you have updated graphics drivers? If you have multiple monitors, can you try to disconnect them and see if there is a difference?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 4 of 27
charitiwashington
I tried what you suggested but it did not help, I recorded my screen to kind and show the issue. Basically the recording shows me trying to click( everywhere I moved my mouse I was clicking) on the different elements, but I wasn't really able to maneuver around any of the viewports and the only way that I can see the sketch that I made was to split into multiples views. Even then I can not extrude or use any of the other tools. Do you have any idea what could have possibly happen especially since it was working fine a few weeks ago.
Message 5 of 27
charitiwashington
I recorded a video, but yes it launches just fine it just doesn't work once it does
Message 6 of 27
RajkumarIlanchelian
@charitiwashington Do you have multiple monitors connected and disconnecting all but the main monitor does not solve the problem, right?
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 7 of 27
@charitiwashington One another thing I want you to try is:
1. Go to Help - Support and diagnostics - Fusion service utility
2. Run the repair Fusion from here
See if this helps!
Autodesk Fusion
Join Fusion Insider
See if this helps!
Autodesk Fusion
Join Fusion Insider
Message 8 of 27
charitiwashington
I apologize for bothering you again, but that still did not work
Message 9 of 27
charitiwashington
No, I just have just one monitor connected
Message 10 of 27
RajkumarIlanchelian
@charitiwashington Couple of things:
1. Are you able to go into Preferences and change graphics setting like @jhackney1972 called out in post #2?
2. Can you let us know what graphics card is on your machine and can you please check if you have the updated drivers for it?
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 11 of 27
charitiwashington
These are the drivers I have and I can go into preferencesfusion360 help 2.pngfusion360 help.png
Message 12 of 27
charitiwashington
I'm sorry, I meant graphics card.
Message 13 of 27
RajkumarIlanchelian
@charitiwashington
1. You have checked that your graphics is up to date right?
2. Also any pending OS updated?
3. Changing the graphics setting in preference I assume did not do anything to help?
Autodesk Fusion
Join Fusion Insider
@charitiwashington
Autodesk Fusion
Join Fusion Insider
Message 14 of 27
charitiwashington
To your first question yes
To your second question no pending OS updates
Lastly, to your third question changing the graphics settings did not help
Message 15 of 27
RajkumarIlanchelian
@charitiwashington OK. This is getting really strange. Let's try a few more things (These are typically graphics but if you are up to date on the drivers then we can look at other things that could be a problem).
1. I see that you do not have the browser on - can you in to View - reset default layout - see if this brings back the access?
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 16 of 27
charitiwashington
I tried what you said, but that still did not work @RajkumarIlanchelian
Message 17 of 27
charitiwashington
Just incase the first video is not playing.
Message 18 of 27
RajkumarIlanchelian
@charitiwashington I am able to see your first video. The second one seems to be processing so I will wait. Which timezone are you in? I can see if it would be possible to have some one from my team to connect with you for a shared call to see what could be happening.
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 19 of 27
RajkumarIlanchelian
@charitiwashington Seems like you reposted the same first video
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
Message 20 of 27
charitiwashington
Eastern Daylight Time
(GMT-4)
I am unavailable until 4:00 pm today
(GMT-4)
