Since yesterday nothing happens when I want to change the color of a body. It still worked in the previous design. Everything I found on the internet didn't lead to a solution.
I hope someone have a Solution
Solved by TheCADWhisperer. Go to Solution.
Try Shift N
if that doesn't work, then...
Here ist the f3d File.
The strange thing is, that all of the colors are suddenly gone in the last project too.
Can you post a screenshot of what you see on your monitor?
Shift Win S and Ctrl v in a Reply here if you are on Windows OS.
Did you try Shift N???
Also, are there any unresolved issues highlighted in your Timeline? (Ctrl b or CMD b)
There were NO Appearances applied to any of the Bodies in your supplied model. I added two to the "N". Open my model and see what you get.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
