Fusion Support
not getting gcode to printer.
3 REPLIES 3
widpyro
125 Views, 3 Replies
I have neptune 4 pro. I cannot get Cura to come up on my print utility. So it is not generating gcode and the image does not appear. Only if custom is pressed does it leave the window but it does not generate the g code.
please adviose what Im doing wrong.
jim
3 REPLIES 3
jhackney1972
in reply to: widpyro
I have answered your private message hopefully showing the process of assigning Cura to your Save As Mesh dialog box as the Print Utility.  Please check your Forum Private Messages.  Please let me know if you have any questions.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
widpyro
in reply to: jhackney1972
I was not given permission to access your video. Please advise as to how I can change the printer utility to accept the model from fusion 360. Right now is only offers “custom” or “preform” I cannot get it to display Neptune 4 pro, and as a result I cannot get it to convert SRL. File to Gcode.
jhackney1972
You have to log into the account you use on the Forum to access your Private Messages.  It was just a reply to your message so I know you have access to it if you log in.  To view you Private Messages, you log in, as you would to post any message to the Forum, then in the upper right hand corner select the letter icon and select your Inbox.
John Hackney
Retired
