Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Cant change Color
7 REPLIES 7
Message 1 of 8
Zugaj_Markus
244 Views, 7 Replies
Cant change Color
Since yesterday nothing happens when I want to change the color of a body. It still worked in the previous design. Everything I found on the internet didn't lead to a solution.
I hope someone have a Solution
7 REPLIES 7
Message 2 of 8
Try Shift N
if that doesn't work, then...
Message 3 of 8
Here ist the f3d File.
The strange thing is, that all of the colors are suddenly gone in the last project too.
Message 4 of 8
@Zugaj_Markus
Can you post a screenshot of what you see on your monitor?
Shift Win S and Ctrl v in a Reply here if you are on Windows OS.
Did you try Shift N???
Also, are there any unresolved issues highlighted in your Timeline? (Ctrl b or CMD b)
Message 5 of 8
Shift + N has no effect
Message 6 of 8
@Zugaj_Markus
Ah, you are in Wireframe visual style.
Try Ctrl 6
Message 7 of 8
You are my Hero! Thank you very very much!
Message 8 of 8
jhackney1972
in reply to: Zugaj_Markus
There were NO Appearances applied to any of the Bodies in your supplied model.  I added two to the "N".  Open my model and see what you get.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
