Since yesterday nothing happens when I want to change the color of a body. It still worked in the previous design. Everything I found on the internet didn't lead to a solution.
I hope someone have a Solution
Solved by TheCADWhisperer. Go to Solution.
Try Shift N
if that doesn't work, then...
Here ist the f3d File.
The strange thing is, that all of the colors are suddenly gone in the last project too.
Can you post a screenshot of what you see on your monitor?
Shift Win S and Ctrl v in a Reply here if you are on Windows OS.
Did you try Shift N???
Also, are there any unresolved issues highlighted in your Timeline? (Ctrl b or CMD b)
There were NO Appearances applied to any of the Bodies in your supplied model. I added two to the "N". Open my model and see what you get.
John Hackney, Retired
