Threads
Threads
amathur
Threads
amathur
Why can't I create threads on the neck of the bottle (on the outside)? Thanks.
HughesTooling
You'll have to upload the model, Right click the component and select export and save as an f3d file. The only idea I have is the surface is a loft and not a true cylinder.
Mark
Mark Hughes
Owner, Hughes Tooling
amathur
It is a loft. I will change it to an actual cylinder. Thank you for your response.
HughesTooling
Just a note on lofts, a loft between 2 circles will form a cylinder you can add a thread to but if one end of the loft is not quite circular the loft will not make a cylinder.
Mark Hughes
HughesTooling
Looking at your model you might want to make the thread bigger than the cylinder you have, something like this.
Make a revolve to add some material for the thread.
Then add the thread to the revolve.
I've attached the file for referance. Also see this thread for info on how to add a chamfer to a thread, the second screencast is the easist method.
Mark
Mark Hughes
Mark
What thread are you referring to?  Did I miss a link?  This sounds like good info to have.  Thank you.
HughesTooling
Sorry forgot the link. chamfer-threaded-rod
Mark Hughes
