Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Stalling at "Hub is being Configured"
119 REPLIES 119
Message 1 of 120
pmarchese
6676 Views, 119 Replies
Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
119 REPLIES 119
Message 21 of 120
I'm having the same issue on the free trial. I tried creating a new username but can't seem to log out and log back in
Message 22 of 120
innovatenate
Is the hub creations still stalling?
Did the sign out issue subside?
Nathan Chandler
Principal Specialist
Message 23 of 120
in reply to: innovatenate
Hi It is still stalling 😞
I have a macbook pro early 2011 15" and I tried uninstalling and
reinstalling fusion 360 to no avail
Best,
Alex
516-967-6797
Message 24 of 120
in reply to: pmarchese
Mine is also still stalling.
Brian
Message 25 of 120
innovatenate
Thanks for the update! I apologize for the issues. The hub creation stall is usually an indication that there is a connectivity issue. Are you behind a proxy server, firewall or something that may impede access to the servers? The install and licensing group has made the below blog post available as a guideline for Autodesk 360. You may want to review this post and see if any of the suggestiosn are applicable.
http://upandready.typepad.com/up_and_ready/2013/12/proxy-servers-and-autodesk-360.html
If you have a laptop, you may consider testing on another network (i.e. at home or a coffee shop) to see if the results are the same.
Also, I'll check to see if there is anything that can be done on the back end.
Nathan Chandler
Message 26 of 120
Thanks. I've tried on 4 different networks and nothing works which means it
has nothing to do with a proxy server. Including a class tutorial on the
software where everyone else in the room was able to get on.
I would really really like to use the software and was planning on
purchasing a subscription after a trial run. Please help!!! It is really
stalling my work. I would even skip the trial period if someone.. would
just help me fix this 🙂
Best,
Alex
516-967-6797
Message 27 of 120
innovatenate
Brian/Alex,
The reset button has been pressed. Please try to log in again as soon as you get a chance. Let me know if you have any further problems.
Kind Regards,
Nathan Chandler
Message 28 of 120
I got so frustrated that i just purchased a subscription. Which does seem
pretty counter intuitive is there anyway i can backtrack to get the free
trial?
Message 29 of 120
jessica.t
Hi Alex! Sorry for the long wait! We're actively working on your request and will keep you posted through this week. If you have any questions in the meantime please let us know. Thanks!
Jessica Thrasher
Message 30 of 120
in reply to: jessica.t
I am also having the same issue (Hub Stalling). I am using a 2012 MacBook Air.
Paul
Message 31 of 120
innovatenate
Paul,
Thanks for letting us know. Can you please try again and let us know if there are any ongoing issues.
Thank you in advance.
Nathan Chandler
Message 32 of 120
All set, thanks!
Paul
Message 33 of 120
I'm having the same problem, it says hub is being configured and has been saying it for the last hour,
please help
nathaniel
Message 34 of 120
I too, have been having the same problem. I have tried creating two different account and still no luck. Has anyone found a way to solve this problem?
Jason
Message 35 of 120
innovatenate
Thanks for reporting this issue! I am in the process of verifying and will follow up as soon as possible.
Nathan Chandler
Message 36 of 120
innovatenate
Jason and Nathaniel,
Everything appears operational as best I can tell. Can you try clearing your browser cache and then re-starting?
Nathan
Nathan Chandler
Message 37 of 120
Hi Nathan,
Thank you for the quick reply.
I have cleared all the caches on my computer, tried two different networks, two different computers and two different log-in IDs, yet it always gets stuck at the hub screen. When I created the account I didn't receive any emails saying the account was registered. Do you think something along those lines are preventing the hub from signing in properly?
Jason
Message 38 of 120
I have the same issue as Jason, but I can't logout to try a different login ID. I also never got any e-mails saying account was registered.
Message 39 of 120
innovatenate
Thanks for the update. I found that I'm able to reproduce the issue if a create a new account. I'm looking into the issue deeper and will return with an update as soon as possible. Thank you for your diligence and patience.
Kind Regards,
Nathan Chandler
Message 40 of 120
Same issue here. No firewall issues. No special characters.
