Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Need help
5 REPLIES 5
312 Views, 5 Replies
Need help
hi i just started useing 360 and now the app will not start up what can i do ? thanks Ervin Adams
Need help
5 REPLIES 5
innovatenate
innovatenate
Autodesk Support
Autodesk Support
Are you getting an error message? What happens when you try to start the application?
Nathan Chandler
Principal Specialist
Nathan Chandler
in reply to: innovatenate
no it just will not start up at all.
innovatenate
innovatenate
Autodesk Support
Autodesk Support
Do you know if the update that was just released has been installed yet? If not could you post the installation log file here for review?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
You may also try the suggestion in the below link to see if it helps.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Occasionally a graphics crash will be pretty quiet.. Are you running on Windows? If so, have you recently updated the graphics driver?
Nathan Chandler
Nathan Chandler
RajkumarIlanchelian
RajkumarIlanchelian
Did you do a fresh install or did you update to the latest build we deployed today? Also are you trying to launch from a shortcut that you created?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
in reply to: RajkumarIlanchelian
Yes i just download it today  i am trying to update my pc now
Sent via the Samsung Galaxy S™II Skyrocket™ an AT&T 4G LTE smartphone.
