Is that possible ??
Is that possible ??
budi67
Message 1 of 39
Is that possible ??
budi67
Hi all,
Sorry for my english, i'm French.
I try to make a Dome of R2-D2, i managed to create the panels of the top, but now I should make a hole on a face of one of these panels, is it possible?
The hole
As the surface is spherical!! I don't found
A big thanks
Best regards,
Budi67
Accepted solutions (3)
Replies (38)
Message 2 of 39
HughesTooling
Just create a sketch and project the edges of one panels and dimension the circle off of the reference geometry you project into the sketch. Then extrude cut using the circle.
MArk
Mark Hughes
Owner, Hughes Tooling
Message 3 of 39
budi67
A big thanks for your rapid answer.
I will try this
Budi67
Message 4 of 39
HughesTooling
Here's a picture that might help, the sizes are not correct but should give you an idea how to construct your sketch.
Mark
Mark Hughes
Message 5 of 39
budi67
I don't understand all, but I has to redo at first the dome because I had imported it of 123d.
But by making the dome with a revolution, the top is not round, any idéa ?
Message 6 of 39
HughesTooling
Make sure you have a vertical\horizontal constraint between the arc centre, arc end and the axis to revolve around.
Screencast demo.
Mark
Mark Hughes
Message 7 of 39
patrick.emin
Bonjour, pour votre information nous avons également un forum en français: http://forums.autodesk.com/t5/fusion-360-francais/bd-p/331
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 8 of 39
budi67
Ok, it's all good, it's my fault, the dome is not a circle but a ellipse.
A big thanks
@patrick.emin Merci beaucoup, j'avais vue pour le forum Français, mais généralement quand je suis sur forum anglais avec une section Française, celle-ci ne remporte pas un franc succés !!!
En tout cas merci, vas maintenant falloir que je vois ce truc de projection, car je doit avoué que je nage !!
Message 9 of 39
budi67
I have tryed with the projection but It is not what I would like.
Message 10 of 39
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here to a Reply?
Message 11 of 39
budi67
I join the file.
I also noticed, by making a cutting in view that my panels are not just, of needs they one the just air, but below it crosses it with the dome.
Seen that I begin, me has to not make the operations correctly.
Message 12 of 39
I_Forge_KC
This is one way to do this.
If the dome shape was perfectly round, I would just use a tangent constraint on the line - but because it is ellipsoidal, the tangent constraint does not work. By selecting the two end points of the curve, I can approximate what the slope would be between them.
Note that the distance between the two lines is of no consequence as long as your extrude cut extends far enough.
This method can be adapted to work at a specific angle as well (for example 45 degrees). In that case the floating line would be dimensioned against a vertical or horizontal line to give the degree measurement.
K. Cornett
Generative Design Consultant / Trainer
Message 13 of 39
Beyondforce
Hi @budi67,
Here you go. Just reverse engineer it to see what I did. Let me know if you have any question.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Gript.app
| YouTube
Message 14 of 39
michallach81
Hole feature is nice but can't be reposition, here's my way ( I've used Ben's file):
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 15 of 39
budi67
It is really great!!! Smiley Wink
A big thanks to all for your answers, i see that thomorrow
In any case fusion is really brilliant !!
I would not miss to hold you informed
Message 16 of 39
budi67
Sorry but i have another problem, i have try to make panels at the bottom Dome.
I tried a method which I considered just, but the measures are not correct.
The 2 etching are not parallel
There, I swim !!, it is all the same infuriating not to find.
Message 17 of 39
budi67
It is possible, I found this ==> https://gallery.autodesk.com/fusion360/projects/r2-d2-dome
I badly has to resound because of the rounding arghhhhh
Message 18 of 39
budi67
What are think about this ?
Ok it's a long procedure, i try what I consider just still by not knowing the tricks
The distances are not still equal.
Do they can beings really parallel?
Message 19 of 39
budi67
I have still tried, but it is not still parallel
Message 20 of 39
budi67
Hi all,
I realized that it is my ellipse which was not good
I almost ended the dome, still the panels of the top.
But I need your expert help, I have another part to be modelled but I do not arrive there, I have already tried several times, but i don't know how to make.
I does not even know by or to begin Man Frustrated
One thank you beforehand
