- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to trace the image, and when I start adding points, the lines all want to curve, like you see on the left side of the "V", and I get the red and green axis how do I turn that off, and make it follow where I put the points instead. seems something has changed since the latest update I got a couple days ago. I did a different one a while ago and could trace the letters just fine, and have just started this new project and have run into this problem. I went back and started a new project with the old image I used for the 1st project and it now does the same thing. Once in a while after I set all the points I would have to adjust a few, but the lines always followed as I had put them down.
thank you for the help
