Creating a bounding box for an organic shape?
- Mute
- Permalink
- Report
I'm surprised I can't find an answer to this already. Perhaps it is simply missing terminology. I don't know what Fusion 360 calls it, so I can't find it.
I often have organic shapes, both 2D and 3D, that I need to fit within certain spaces. In Rhino3d there is a very useful command for generating a bounding box of the sketch or body. That way I can see the extents of an otherwise complex organic shape and determine if it will fit the maximum allowable dimensions.
How do I do that in Fusion360? For example, if I have a sketch that is built of multiple flowing spline curves how can I automatically determine where on the sketch is the "high water mark"? Think, for example, of a stylized cloud shape. It is hard to even know which curve reaches the highest just by eyeballing it. I need some way to calculate the extents EXACTLY in x, y, z.
That bounding box would likewise be useful for scaling the object to fit the parameters. If, for example, the object has to fill but not exceed a 3cm cubed space I could measure the existing edges and scale the object in each dimension by 3 divided by the measurement.
What is the way to do this in Fusion360?
Thanks.
