Message 1 of 20
03:44 PM
I have a kite geometry of two surfaces that I have joined together and stitched using Fusion 360 PATCH section. I now have converted this to a solid body successfully, although the resulting body has bad geometry at the trailing edge.
It is an airfoil type geometry.
How can I fillet this either once solid, or at the surface stage? I have tried filleting the solid but it does not work, and can't select the edges in surface mode. 😕 I am stumped. .It is needing a smooth edge for meshing purposes.
Any help greatly appreciated on this!
Adam
