I'm trying to build a mechanism to split a big magnetic apparatus apart.
The contact sets i applied don't work. they do for half of the way, then they simply stop working.
i even inserted a sphere so that the contact is made through single points, to no avail.
could anyone help me out here?
Thanks in advance,
Sw1ssdude
Solved by ninolemann. Go to Solution.
How far does the Slider have to go?
I get the wooden block tangent to the sphere and at 33mm the block will start to close.
Since I started using Fusion I have only seen strong recommendations not to use Contact Sets, for reliability and performance reasons, therefore I have never used them, and don't know what is expected behaviour.
I would go with another motion link, slider 33mm and revolute the correct angle, but I could not measure that, without editing the file, and will do that if more information will be required.
Might help.....
I just kept on modeling, working out all the fine details, and suddenly, the contact sets worked just fine.
The function remains a mystery, but for me, this thread can be closed....
Good Luck!
