Contact set glitch
4 REPLIES 4
ninolemann
433 Views, 4 Replies
Contact set glitch
I'm trying to build a mechanism to split a big magnetic apparatus apart.
The contact sets i applied don't work. they do for half of the way, then they simply stop working.
i even inserted a sphere so that the contact is made through single points, to no avail.
could anyone help me out here?
Thanks in advance,
Sw1ssdude
4 REPLIES 4
ninolemann
in reply to: ninolemann
bump...
davebYYPCU
How far does the Slider have to go?
I get the wooden block tangent to the sphere and at 33mm the block will start to close.
Since I started using Fusion I have only seen strong recommendations not to use Contact Sets, for reliability and performance reasons, therefore I have never used them, and don't know what is expected behaviour.
I would go with another motion link, slider 33mm and revolute the correct angle, but I could not measure that, without editing the file, and will do that if more information will be required.
Might help.....
ninolemann
in reply to: davebYYPCU
Thanks fort he reply!
In this cylindrical design a huge steel cylinder will be inserted. If you ever worked with neodymium magnets of the size of a marsbar you know how terrifying magnetic forces can be...
This is why I quickly drew this clamp, which can be split by that wedge-like tong, which would keep the magnets apart in a safe way, while the tongs push out the inserted steely cylinder to the side. The ball is just there for single-point contact.
I didn't use another motion link because I'd like to evaluate different wedge tip forms, so the motion link wouldn't be linear - a formula generator is still missing in FUSION - and I was hoping for some input of how to facilitate things for fusion. The behavior of the motion link is a bit arbitrary, and I guess there are some do's and don't for the contact set, which is after all a very powerful tool (if it works)
ninolemann
I just kept on modeling, working out all the fine details, and suddenly, the contact sets worked just fine.
The function remains a mystery, but for me, this thread can be closed....
Good Luck!
