2D divide a flat surface for coloring purpose
4 REPLIES 4
481 Views, 4 Replies
I'm finding no solution to a simple problem. I'm modelling a tablet and I would like to divide the top surface in order to colour the screen. I've designed a rectangle on a sketch for the delimitation of the screen but can't manage to apply it on the surface. I do not want to extrude as it should remain flat.
Any help?
Tags (3)
4 REPLIES 4
jeff_strater
Use Split Faces to divide the face, then use Appearance with the "Faces" filter set to color just one face:
Jeff Strater
Engineering Director
JeromeBriot
another solution could be to place a decal on the surface:
in reply to: jeff_strater
thanks
in reply to: JeromeBriot
Merci pour cette solution.
