I'm finding no solution to a simple problem. I'm modelling a tablet and I would like to divide the top surface in order to colour the screen. I've designed a rectangle on a sketch for the delimitation of the screen but can't manage to apply it on the surface. I do not want to extrude as it should remain flat.
Any help?
Solved by jeff_strater. Go to Solution.
Use Split Faces to divide the face, then use Appearance with the "Faces" filter set to color just one face:
another solution could be to place a decal on the surface:
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
