Dynamic Blocks Forum
Is it possible to create a Attribute that changes based on the length of my block?
5 REPLIES 5
hcontesti
315 Views, 5 Replies
Hello, I have a block that i want to make and i was curious if there was a way to make an attribute that is linked to the length of the block. I have the distance1 parameter and a stretch parameter in my block
5 REPLIES 5
hwalker
in reply to: hcontesti
No attribute length cannot be changed, by stretching a block. It will always be fixed to what you set it as when you create it
Howard Walker
Left Handed and Proud
Libbya
It depends on what you mean.  You can change the attribute value based on the length of a linear parameter by using either a block properties table or a lookup.  You cannot dynamically change the text width of a multiline attribute.
hcontesti
in reply to: Libbya
Basically the text will be invisible, i just want it to show up when we use the data extraction command so we can have the length in the table to make estimating and quoting easier
Libbya
If you just want the text to show the length of a parameter then that is quite easy.  No need for block properties table or lookup.  Just use a blockplaceholder field in the attribute referencing the distance parameter.
hcontesti
in reply to: Libbya
Thank you very much. Im still learning all the options available with AutoCad Blocks
Forma Design Contest
AutoCAD Beta
